I just went under my recently purchased 1995 Cruiser for the first time to change the oil and noticed that the O2 sensor cable was rubbing on the drive shaft, clipping it. I have been trying to diagnose an emissions problem.
1. What is this doing to my fuel ratio and emissions inspection?
2. I tracked the cable up and over the transmission but lost it from there. Where does it go so I can replace it?
3. Will I learn new curse words doing so?
I have 94, on mine that wire that goes over trans and into the bundle of wires that is next to the PHH (if you know where that is).
Its under the intake manifold around where the trans dipstick is. There are a lot of wires under there. The O2 wires go into the harness there (no connector plug) I pinched my O2 wire between trans and engine when I installed the trans. I dropped the trans again and spliced the wires where it was pinched. You can't just buy a new O2 wire (you could buy a whole wiring harness and rewire the whole motor but its not needed for your repair)
All you need to do is splice the wires where its cut. One of the wires is shielded so try and find a shielded wire if you have to extend the wires. Regular butt connectors will do the job.
You should not use dielectric grease in the butt connector as it could/might affect signal (I used it in mine when I did it with no know ill affect but would not do it again after reading up on dielectric grease and O2's)
On my 94 when I unplug both O2's (they are side by side and installed in front of cats) my mileage is not affected nor is performance. All I have noticed is it idles better with new O2 over running with them unplugged. With them unplugged, the motor runs in a default mode (something to do with "open loop" "close loop")
Not sure how the 95 O2 are mounted (before or before/after cats and if cats are inline or side by side) so I cant say what is happening with your 80. I am sure you would not pass emission test if you live in a area that has stringent emission requirements.
No new curse words are required, old ones work just fine.
Sounds good. Thanks. My cats are in line. I have only looked at this one sensor. So I have not looked to see where the other is. I am sure it is on the back side of the two cats. To be honest, that is what I was hoping to hear. This makes it a lot easier. Our emissions are tail pipe for OBD I and a tach. So as long as it blows OK, it is not a problem. But I am surprised there is no check engine light on?
