1997 80 climate control when set on AUTO blows high fan HOT. When I move the slider down to appx 65 it blows high COLD. This makes for an interesting ride but the wife is complaining. Does anyone have a fix? My local Toyota dealer is outrageously expensive!
make sure the temp sensor is clean, it hides behind the slotted the lower left portion of the AC cluster that has a a few slots in it. Try blowing some compressed air on the sensor to clean it of dust. Or the sensor could have become unplugged.
The automatic climate control system has been discussed a lot here in the past. I'd think a search would reveal a few folks with your exact symptoms, as well as the most likely fixes.
Your sensor clip has come undone behind the dash...plug it back in. Go ahead and blow some canned air on the sensor if you want too...I just slightly blew mine off and wiped with Q-tip. Mine and a few others on here have done the same thing...mine happened after a stereo installer installed my satellite radio and he re-plugged back in the wrong clip to the sensor. It will be plain to see your problem once the trim piec is off and you view behind the sensor. With the difference in the cost of my fix vs. the dealership you can take me out for steak dinner!
I agree with this gentleman. That panel is real easy to remove just becareful not to break any clips... You can find instructions on Slee.com for the center diff switch. They will show you step by step how to remove the panel. Then just follow the above advice. After all, the last thing you need is for the little lady or management as I call her to complain. Then she start down the road of "why did you buy this car anyway?" You know why! It's just hard to explain it to them.
Now, when you do the above and get it buttoned-up find a good radiator/ A/C shop. Have them do a complete flush and recharge of the A/C. I did this. Now management is saying she is to cold. I keep a blanket on the back seat for her now. Even on 100+ days our a/c's can work pretty darn good..
