climate control issue
Is the AC supposed to kick in all the time when using automatic climate control? It kicks in even when it is -10 in the vehicle. Does anyone know what the problem is?
No one else is chiming in, sooo, I know that the A/C is used as a de-humidifier especially when the defrost vents are selected (even partially) regardless of outside air temperature. Might be what you're seeing. Just set heat control where you need it and you shouldn't have a problem.
I was told it is supposed to do this...it is normal.
