Climate control help
Memphis, TN
I have been lurking around for some time without any reason to post until this past weekend when my heating and air conditioning stopped working.
I have a 97 CE with climate control and while i was driving around in Tellico this weeknd, which was really fun besides the snow, the heat and all the air sysyem stopped working. The only heat I had was from the rear heater. All the lights work except the middle row of buttons like the AC, auto, and recirc buttons, it just seems like it is not getting any power.
I searched and searched on mud and then I started taking everything a part today to see i f i could solve the problem. I checked the fuses they all seemed ok. I then switched the controls to manual and the recirculation button turned on but still no air. I also cleaned off the climate control sensor but that did not work. I really do not think anything is wrong with the controls but with something else. does anyone have any insight about this.
In my case, my AC/heat did not work due to one of the climate control circuit box shorting out due to some water infiltration. I still haven't figured how how water got into it.
You may want to check for a loose connection to this box.
The circuit box is located in front of the driver seat attached to the firewall. It has 54 pins and 3 cables attached to it. If you were sitting in the driver seat, this box would be located above your right knee against the firewall. You most likely need to remove the air vent tubes beneath the steering wheel to get access to it.
Hope this helps.
Besides the fuse, there's a lot of electronics controlling the heater/fan/AC, any one of which could be responsible. That's probably why you're not getting much of a response.
There is an ECU believe it or not for the climate control. As noted above, it's behind the glove box on the right. Have no idea how to test it, but that may be in the EWD book. There's also a large resistor that resides in the cooling box, I suspect if that's shot, your system won't work too. Also, there's a temp sensor in there somewhere too that could be the problem. You're going to have to troubleshoot this to figure out which bit is the problem...maybe someone here knows how to do that.
I now have exact same problem, No A/C, all buttons work except middle row.
did you every fix it and if so what was it?
Bueller, Bueller......
Any help would be appreciated, all searches have no solutions only open ended questions.
The Factory EWD For the CE and the 40th anny.are useless = Order the Lexus 450 EWD . The auto airs installed in these special vehicles are robbed out of the LX450s. I have found many with control unit water damage due to poor windshield installs. Check for water damage (green stuff) growing in the computer or its connections. Good hunting. Bill
