CLICKING IN TRANSFER CASE
Corona, CA
1993 Land Cruiser Unlocked
Ive recently been tracking down a wacky speedo issue. Today I decided to pull the speed sensor gear out of the TC and couldn't really see anything stripped or broken. I put it back in, drove around and started to hear this clicking/clanking noise down below. Here are some highlights:
-doesn't make a sound when giving it gas in park/neutral
-doesn't make a sound when backing up in reverse
-makes clanking sound in Drive *only* when giving it gas (clanking goes away when coasting in drive)
-pulled the speed gear and it made clanking noise even without the speed gear in when driving slowly
I scoured the search tool but only came up with bad axles or birfs, etc... I think all these aren't the issues since I literally just got this noise after I pulled the speed sensor gear.
Do you guys think something fell inside when I pulled off the gear part? the c-clip on the gear body is still on, didn't fall off. scratching my head on this one.
well whatever was in there is probably shredded. the clicking stopped. haha.
My speedo issue is the same as everyone else that has a speedo issue. works sometimes. replaced the sensor with no change. decided to look into the gear that controls the sensor to see if anything was chewed up.
