Clear coat peeling off: Nip in the bud
San Diego
I found a small patch of clearcoat had peeled off the paint. Its about the size of a quarter when I saw it. I tried to polish it off but its now the size of a silver dollar. So, I stopped messing with it.
What can I do to prevent further peeling of the clear??? :confused:
It's in an inconspicous area but don't want it to get of hand the next time I seek it.
in the late 80s early nintys this problem was common on all autos, chances are you could get some buffing compound and a buffer and help some, but most of the time it spreads like cancer. best soultion is a repaint when its real bad
Only way to prevent further peeling is to park it in the garage...but that doesn't help you. At some point, you probably need to knock down the affected panel with ~ 1600 grit, tape it all out and re-clear the affected panel. My 02.
My brother had a couple of spots on one door where the clear coat was failing. The big spot was right along the window molding, we removed the molding, taped at the body pinstripe and sanded all of the good clear coated area with 320. In the area where the clear was gone we were very careful with the prep, get it clean and remove any loose material, but the lower paint coats are relatively fragile and too much prep will change the color. We used some fine steel wool and lacquer thinner, most of the loose, flaking clear was first removed by scraping with my thumb nail.
The other spot was at the edge on a body line, like someone was too aggressive with the buffer and removed the clear in a small area. We prepped and back taped, that small area, 1.5" x .5". To back tape, fold about 1/4" of a piece of 1" over so that the adhesive side is up, stick the 3/4" sticky side to the body, then adjust the 1/4" flap so that it's about 3/16" off the body. This makes a tapered edge on the new paint, making it much easier to blend.
Sprayed it with Krylon industrial clear that we got at an auto paint store, about 4 good coats. Came out very nice, there is some discoloration in the area where the clear was missing for the longest, it looks much better. Will see how long it holds up, but it's much better than the missing clear coat and probably greatly extended the usable life of the paint job.
Like any paint job the key is prep, the area must be clean of any wax, etc. Anywhere that the paint is going the shine must be removed, sandpaper, scotch bright, steel wool, etc. If the new paint doesn't have tooth to stick to it will peal, flake off, looking as bad or worse than before.
would appling some wax help protect the clearcoat?
I'm a believer, I've waxed my 96 F-350 a lot especially during it's early years and so far the paint looks like new.
Now for my 92 Camry that didn't get much loving, it's got the cancer bad.
