cleaning out the garage.
Colorado
I have some things I would like to get out of my garage.
1) $50 -- 1 set of Spidertrax Samurai birfield rings. Used, but in good shape. If you bring me your axles I can press them on for you for free, but you will have to do some grinding to make them fit inside the knuckle.
2) $175 -- Allpro offroad 2nd gen 4runner links. Uppers and Lowers. Uppers are heim joints and lowers are "johnny Joint" type. 1 1/2 longer than stock to move the wheel back to center after lift, plus give you a lot more flex. Allpro does not carry these anymore. Two of the upper link ends have a little play in the ball, they are easily replaceable. The lowers are rock solid. Might work on 3rd gen too, not sure.
3)$30 -- Holley GM throttle body. Complete 4.3 version, but only the lower is usable. Barely used before the injectors started leaking, injectors are not available anymore. Switched to stock style fuel pod and just used the Holley lower section to get the 2" throttle bores for increased CFM.
4)$100 -- 1999 Chevy vortec cylinder head. Valves freshly ground with hardened exhaust seats installed and head gasket surface machined flat. got back from the machine shop and has never been installed. Have paperwork.
SOLD! 5) FREE -- 2nd gen 4runner drivers seat. pretty dirty and has a couple holes, maybe you always wanted to see it the better 2nd gen seats would fit in your 1st gen? Now you can try for free. Or just leave it in the garage like I have, the kids love it. GONE!
SOLD! 6)$80 -- Old man Emu Landcruiser FJ80 front lift springs w/ coil buckets, isolators, and bumpstops cut out of my 4runner. These used to be sold by Allpro offroad, they lift the rear of a 2nd gen 4runner 5.5 inches. I think they lift the front of Landcruisers 2.5 inches. With coil buckets and all the brackets included, you could put them on anything.
7)$50 -- Ladder rack for small truck. Not sure what it fits, but it don't fit a Toyota. I was told it came off of an S-10. The bed would have to measure 76 x 49 1/2 for it to fit inside the rails.
I have pictures for everything.
Thanks, Luke.
Your garage floor would almost pass the white glove test.
Would you mind posting a short description of the Hotel Gulch trail area? Suitable for stock rigs? What's it like? Thanks, Vic
