Classic Cruisers PS kit
Redding, CA
Anybody out there install this kit http://www.classiccruisers.com/pages/conversions.html on their FJ40? This kit allows for retention of stock air cleaner which I like. What I'm wondering about is that their kit is that it uses one belt for everything, water pump, alternator and PS pump. I am concerned about the belt to pulley surface area. This kit is all inclusive and I want to tackle this project myself except for the welding of my steering shaft. This will be my first project and just want to make sure of which way to go. I have heard many good things about Dorry's brackets but they do not allow for stock air cleaner. Trying to retain stock appearance to my 71.
With this kit you don't have to do any steering shaft mods, The gearbox bolts right up to your existing rag joint like the stock one. It does use 1 belt and it works fine. The kit is a little pricey, but its all new or rebuilt and bolts right up, That is after you remove the stock gearbox. If you plan to run 35" or larger tires, or a front locker, go saginaw or scout and save doing it again. ASK ME HOW I KNOW !!!
My 71 does require that the one piece steering shaft get cut and welded. I believe they changed in 72 or 73. The price was not as bad as first thought when I priced all items out, came to about $100 more for the kit. What I would not get is directions and telephone support which are valable to me since I haven't done this or anything like this before. Price is up there so was hoping for some more input before I order.....
I did a Classic Cruisers Power steering Kit on my 66 40 with a 2F. The kit was very compleate including instructions , all the right bolt's everthing from hoses, belt to rag joint
(used ) :frown: & sterring shaft bushing .The only extra I did order was a sterring column mounting plate plate from Man -A- Fre .You do have to order upper OR lower pump brackets as I used a 1F type air cleaner and used the lower mounting bracket ,worked out well . Bolt up farly EZ less than 1 hour :banana:
( body was off) Havent run it as of yet, still working on body and paint.... JC
This kit looks pretty similar to the one that I did... with the mini-truck PS box. All things considered, I did mine for less than $300.
I bought the PS box from a guy selling them at the Pirate 4x4 boards for $10. The Saginaw PS Pump came from a local Volvo repair shop that sells used parts, and the pump and pulley (which works just fine) cost another $25. I bought the brackets here on the boards for $180 or so, from William Dorry, who makes very nice ones.
The high pressure hose for the toyota box fit the volvo pump (but I paid to have a new, longer one made anyway) and I bought some return line for a few bucks, and a belt from Napa. All in all, it was easy and not too expensive. Over 900 seems a bit much, and there have been a few write ups about doing this (search) if you need instructions.
The biggest pain was getting the pitman arm off of my box.
Anthro
