clacking sound
Not sure on this but does it happen as soon as you shift and before you move, or does it start when you begin to move backwards?
If under movement I would thing something sticking in a brake rotor or shield, or on the driveshafts that only catches in one direction. If it happens while sitting still it almost sounds internal.
foot is still on brake when i shift to reverse , clacking will start......last for a few seconds while moving...only when its been sitting over night and its cold
May need some more info on this one, can you tell if it sounds like engine or under carriage?
My engine shroud sometimes slaps around and sounds pretty nasty, especially when cold, and then mellows out.
May need to just get a buddy to listen under the hood and truck to see if you can narrow this down a bit more, pretty hard to diagnose at this point.
Is your Hi/Lo shifter touching anything like power or audio cords? Also listen closely in this area as there are small clips that can break under the shifter boot and can rattle slightly. I was chasing a rattle for weeks that turned out to be my audio cable touching the vibrating Hi/Lo shifter.
THIS IS COMING FROM UNDER CARRIAGE WHEN ITS COLD AND IN REVERSE FOR A FEW MOMENTS.....RAPID CLACKING
I HAVE....THAT WAS MORE OF A THUD FROM THE REAR.....GREASE FIXED IT
Could be your brake pads. I've heard of some toyotas doing this when going in reverse and on cold starts it will cause the pads to hit the caliper so you hear a clacking sound. Try putting some grease on the backs of your pads and see if that helps.
i will give it a shot...thanks
