cigarette lighter removal
charleston,wv
I've searched and haven't really found what I was looking for. How do I remove the cigarette lighter, I know if you take the ash tray out there's two screws to remove. Wasn't sure if there were any tricks or anything.
Remove those, and I believe there is a third in there, and continue on by remove the dash (this section is really easy to pull). Pretty much home free from there I believe.
For a '96 there are 4 screws that hold the center console in. Two behind the ash tray, and two behind the blank/tray where you can put a cup holder (that skinny worthless little thing in the upper right of the console).
Once those four are out, it is held in by clips. I always start from the bottom right, it will just pop right out. Be careful not to stretch the wires too much or pull them loose unless you know what plugs in where.
