We went camping over the weekend and the cigarette lighter plug provided no power. i took the dash apart to ensure that it was plugged in. Check. No fuses out either...
What say the forum?
What say the forum?
On the back of the lighter there is a fusible link that burns if there is too much power draw. You can use some needle nose pliers to loosen the clamp pieces and move the link a bit to get some connection on each end and reassemble.
Alternatively, there is a procedure here (you'll need to search) to eliminate the fusible link and rely on the fuse for the lighter to prevent a fire. I did this two years ago because my phone charger kept burning the link.
Take the nut off the back of the lighter socket, remove the fiber washer. Reinstall everything minus the washer and you're good to go. Just remember as stated earlier you lose the thermal protection the link provides, so if you run something for a long time make sure to take breaks.You are the man, this was my problem!
Searching for the fusible link bypass right now!
Cheers!
