Cigarette Lighter Electrical Issue...
Whidbey Island, Wa
My cig lighter quit providing power on a trip across the country a while back and I am trying to fix it now.
I have read the wiring diagram and know that it should put out 12v with the ignition at ACC or ON, mine only kicks out around 9.5v at the lighter itself.
Tracking it back it puts out 9.5v also at the fuse in the fuse panel, which I would assume should be putting out 12v as well.
The clock that is tied to the circuit works fine, but I am guessing it would probably work with 9.5v.
I also believe the fusible link behind the lighter plug is good since I get a voltage reading there.
At the time of the loss I was probably over using the receptacle by getting an adapter and running 3 12v items on the trip. (cell charger/GPS/DVD for the kids) Anyhow, I know that I need to put together a second fuse box and additional 12v's off that, but for the time I just need the cig lighter back to charge my cell phone.
Any advice is appreciated.
Thanks,
Dave
The circuit the cig lighter is tied to has a lot of different stuff on it. I would be surprised if it was working with 9.5v.
Are you sure you're reading the voltage correctly?
I would lean towards the fusible link on the back of the cig lighter as being the culprit, especially if you were pulling too much power from it at the time when it died.
Perhaps not the answer you are looking for, but I would consider just hard-wiring one to the battery with it's own fuse. Did this in my truck with 12ga wire so that I never had to worry about the draw with accessories.
cyclosteve-albums-arb-lockers-oem-switches-lights-picture10514-console-black-12v-constant-accessory-plug.jpg
Did you measure voltage across the fuse holder? Just wondering if you measured from there to a body ground if it would read the same? Otherwise, it could be a bad ground.
But as Ebag said, 9.5v may very well be normal.
Measured from both sides on the back of the fuse and at the plug, and with the cig lighter plugged in and all read 9.5v. Additional info, I start the truck and get around 11 +/- which should be enough, but still no actual power when my charger is plugged in. Is there a possibility that the plug that receives the lighter is not transmitting the voltage.
