71 FJ40 F engine...
To get it to start up, have to pull the choke open. That's fine with it's cold, but once it warms up, it won't fire up unless the choke is pulled about half way. Seems to me that it shouldn't need to be choked???
One thought is maybe timing. Right now it's at 7* before TDC, which I'm told is the stock setting. Tried to retard it a bit more. I thought that you'd just unclamp the dizzy and rotate it, but not the case. 74K5 knew about a bolt on the distributor that adjusts the timing. Well this bolt broke off when he was adjusting... were we doing this right?? Have a spare dizzy, but there's no bolt on it like the one it there has.
Exhaust gasket has a leak on it. Thought it was the valves need adjusting actually. How important it is to repair?? The head that's on the motor was replaced by the PO. On the old head, the exhaust valve is burnt on the same cylinder the new head is leaking... hmmm. Warped exhaust manifold maybe??
