Chirping Sound?
ajs
Pasadena CA
My LC has developed an annoying chirp. Anybody recognize the source?
* Happens only when moving
* Can only hear it at low speeds (under 25 or so)
* Happens both when foot on gas and when coasting
It's been surprisingly hard to capture the sound. It seems my iPhone is much better at picking up tire and engine noise. In the video, the chirping is pretty clear as I slow down and stop (second half of the video).
If I had to guess, I'd say it's something suspension-y, though it doesn't seem directly related to bumps. When it's happening, at certain speeds, it's pretty constant, just chirping and bumping along.
I'm not sure what you mean by the cab twisting...
Maybe your truck is trying to tell you something in morse code?
I have a very similar noise at the moment, just maybe slightly higher pitched; mine is rotational and definitely on one side (passenger side)
What does it sound like with the windows down?
I think mine is passenger-side too. I'll verify later today when I can get someone to ride with me.
Just went around the block with windows down. Here's another example.... didn't change substantially when I went over the dip in the road... just chirping along.
Jumping in here with something that may or may not be the cause but might help a future searcher. I had a high pitched chirping sound coming from the passenger side and it ended up being the heater blower. I had intermittently heard it earlier in the year but now that the cold is here in full swing I heard it more consistently.
There have been prior threads on it but it could be as simple as a leaf stuck in it (not the case for me) or it just goes bad and time to replace. I replaced mine with a junkyard one I found from a sub 60k mileage vehicle. Toyota used the same blower in a few vehicles so was easy to find a replacement.
To test if that may be it I’d park the car, turn the heater fan all the way up and go around to the passenger side and put your head near/under the glovebox. You’ll easily know if that’s it
Yea, is the blower on the lowest setting? Turn it off and see if it goes away
For me, this doesn't seem to be related to the blower.
For future searchers... it was the top nut on my OME shocks. I tightened them a little and the sound is gone.
