Chirping/ rubbing sound
I replaced my clutch and also rebuilt the transfer case on my 71 Fj40 over a year ago.
After coming off the trail last weekend, I noticed these sounds coming from what sounds like behind the intrument cluster. The sounds are intermitent. They become most noticeable when I am making a wide, right turn or when I go over a bump. And then it only lasts 5-10 seconds before subsiding.
I suspect something in the clutch as I would also notice it when I let out the clutch in first and second, NOT in reverse.
Any help is appreciated.
Speedo cable will make a chirp when it wants lubrication. And mine is right behind the instrument cluster.
GL
Ed
Alex,
I think we're going to need some more information since the 3 things you list have little connection to them .... instrument cluster, right turns, and clutch.
Do some more isolating such as:
Does it only happen when moving?
Were you in deep water or mud when on the trail?
Does it sound like the kind of "screech" a bad bearing might produce?
Could it be as simple as a loose fan belt (alternator).
Off the cuff there are a list of maybe's:\
1. dirt/mud on the clutch
2. throw out bearing shot
3. Speedometer cable (mentioned above)
4. bad motor mount (allowing fan hit something when the engine is torqued)
Right now if I HAD to guess, I'd go with number 4.
Rice
See Alex that's what ya get for beatin the holy hell out of it...Actually Blame it on JP and his stupid tire that crashed into you. But I would also guess the speedo cable, I believe I had the same kind of noise happen before mine broke. Probably why it broke, no lube. Good Luck
Rice said:
Alex,
Rice
Yes. It ONLY happens when I'm moving (first letting out the clutch or when on a right turn).
Yes, there was snow and mud on the trail.
I do not know what a bad bearing my sound like.
I'll check my bearing.
What is a good way to check motor mounts?
To check motor mounts W/O looking at them...
Set parking brake, put in first gear, ball of right foot on brake, heel of right foot on accelerator, slowly let out clutch, if you have a bad MM, you should hear the same chirping sound.
I still think it is the speedo cable. Lube it like Chef suggested.
Ed
