chevy 350 help
Do you have a motor number??? If so there are several places on teh web to check the motor number and find out what year the block is....
http://www.mortec.com
front of the block, flat spot by where the water pump mounts (topside) - stamped numbers
backside of the block, behind the flywheel - cast in numbers
between those and the website above, you'll find all you need to know
