Chev auto tranny
brownbear
Mod in Hibernation
Moderator
Hamilton, Ontario
Hey guys,
So I have a corvette question. My folks have a 75 vette with a 350 and Turbo400 auto tranny.
I have been wanting the 4th gear for awhile. Is there any 4speed autos that would mate up with the 4th gear that would easy?
The least amount of issues the better. I just think this car needs some lower RPMs on the highway.
But we still have to stay automatic.
Also what years and models did the 4sp autos come in?
Thanks, BB
700R4 is the way to go it is a 4spd unit w/ od. It is a few inches shorter than a TH400 & mounting location is not the same. Drive shaft yoke and length will be different and you will need to fab up either a new cross member or creative mounting. If you get seriuos pm me or email me, site is below. I can give you more help.
Thanks for the help. I just might contact you.
Is there any different 700r4's? Like ones I should look for at a wreaking yard or what not?
Is there a better year for them?
Any issues with the torque converter or mounting to the 350?
Thanks, BB
Seen your website. Your not too far away from my folks. Just a border away. They are in NW Ontario.
Do you install the transmissions, or just rebuild them specifically to the needs people want?
This corvette they have is used primarily for cruising around. Not dragging or sport driving. But a solid feel is nice. It doesn't need to feel all slippy.
700's have a few variations, externally they are the same.(as far as 2wd/4x4) Ideally you can get yourself a pre87 unit then I can tell ya how to make to lock-up with out electrical hookups. I build & install so anything you are lookin for just ask. The torque converter that you'll find in any stock unit should work ok for you, the stall speed change is minimal. If you'd like to get a reman I can ship you one out too. That way you know you have the right stall.
Why bother with a 700 when you could do a 200-4R ? The 200 has the same gear ratios as the TH-400, but with an overdrive gear. The 700 is heavier and has a horrendous 1-2 gear drop. The 200 can be made very strong and reliable. I have a friend that builds them for GN's running 9 second ET's.
2004R's are harder to find and to find parts for. They can be built up
but it's costly to beef one up since they are inherently weak. They are after all a 200C with an added OD. On the drag track they like them since the guts are small and light.
Thanks for the responses. I will let you know.
Nice thing about bring over a tranny is no duty.
Cool :)
