Cherry Bomb.
Fort Apache: Victoria
I'm going to be due for a new muffler fairly soon.
I see the Cherry Bomb is being made again. It's so small and low-profile I can see it being clear of rocks and tree stumps pretty much all the time.
Is anybody running one?
Extremely quiet? Louder than the stock muffler though right?
I'm considering getting a glasspack, and I was hoping for some noise. Not stupidly loud but loud enough.
If you want maximum flow along with a fairly quiet muffler, Id suggest a Magnaflow. You can get them in all sorts of shapes/sizes, so you may be able to find one that is fairly compact, and due to their design, they flow better than a glasspack, which (the last one I saw) had inner perforation (like a cheese grater) going the wrong direction to be optimal for flow. The Magnaflow has no such impedance. But thats just IMO....
I'm running a glasspack on my '92, tucked tight and extremely quiet (compared to V8 or Diesel rig), even with gutted cats. I attribute this to all the curves in the exhaust and the tail pipe exiting in the back corner stock like.
Are you running your stock resonator as well, or just the muffler?
Glasspack is as compact and free-flowing as you can get, just go grab a magnaflow and a glass pack and blow into either, that's as good a test as I can see.
The only difference between a Magnaflow and a "glasspack" is the material used a sound deadener. Both are straight-thru designs. The traditional "glasspack" uses fiberglass packing (hence the "glass" and "pack").
Magnaflow uses steelwool and an undisclosed "acoustical absorbent material" (they claim it is not fiberglass). I am pleased with my Magnaflow's sound level.
Early glasspacks had a tendancy to get louder as the fiberglass became burnt or just blew out the tailpipe, not sure if it is still an issue.
Magnaflows have baffles and/or internal bends to helps create/reduce sounds. Glasspacks do still get louder with time, but mine was used when put on and sounds great and is extremely quiet, especially considering my expectations of a loud obnoxious sound.
I had magnaflow exhaust on a 6cyl 4L SOHC engine and I swore to myself I would never buy another magnaflow muffler.
The drone was so horrible and intolerable... even with a resonator.
There really are too many variables for muffler selection to throw one out due to one experience, although a magnaflow or flowmaster will have more of a drone/rumble than a glasspack or turbo muffler, and without the bends in the exhaust on my 3FE, I doubt a glasspack would be acceptable.
Better tell them, this is from from their website.....
Question: Why is MagnaFlow the best exhaust system?
Answer: Nothing performs better, looks better, or sounds better than MagnaFlow Performance Exhaust. Our Research and Development Team invests many hours to ensure our products stay competitive and perform the way they should.
Our systems feature straight-through flow designs for the ultimate in unrestricted horsepower and torque for big power while maintaining exhaust efficiency.
The internal MagnaFlow muffler is designed of stainless steel perforated core, stainless steel wool, and an acoustical absorbent material -- superior to fiberglass (which many
other manufacturers use). No baffles, chambers, or louvers. No restrictions at all, just straight-through, wide-open performance with a smooth, deep tone, and each MagnaFlow stainless muffler has a highly polished mirror finish for a show car look.
http://www.magnaflow.com/07techtips/faq/question06.asp
I know mine is a straight-thru design
