- Thread starter
- #21
Is your new preload measurement the same as when you finished the rebuild?
-KK
I set the preload at ~15 to 18 ft.lbs. (on a pull scale) originally and when I checked it after 300 miles it was consistently at ~12 ft.lbs. I just could not get it to stay below 10 ft.lbs. once I torqued the outer nut on. I would have the pull at 6 to 7 ft.lbs. then torque the outer to 43/47 ft.lbs. and it would always come out in the high teens. After reading suggestions that setting it a bit high originally was a common practice, I just went with it.
Riley
