checkin tranny levels
City that rhymes with fun
ok another rookie question, where abouts do you check the tranny level in my cruiser, itsa 67 wit hthe 3 speed.......what should the level be at? is it true you put gear oil in the tranny?...............................
80w90 in tranny, tcase, diffs...
Fill plug is on the drivers side of the tranny, in the middle.
Should have oil right to the edge of the fill hole.
Good luck!
-Steve
hey poser one more thing........if i just pull the plug under the t case will that drain the tranny also or are they separate, and just how much oil will be required to refill them. the level seems up but its very thin and runny so im gonna change it out....
The tranny and tcase have seperate fill and drain plugs...
Hot gear oil is going to be a bit thin...
I would get 5 quart bottles...that will cover you...fill the tcase to the bottom of the fill hole, just like the tranny.
Good luck!
-Steve
They should be drained separately, which is why there are two plugs. Unless the seal between the two is leaky, in which case the tranny will empty into the transfer case all on its own while you drive (bad).
Not sure (don't have manuals in front of me) but I think 1.8 quarts for each is about what they take.
