Check your plug wires (..at night)
Rhode Island USA
My 62 runs really well, no misfires, drives well on the highway. Since I got it back on the road, the idle was been a bit more rumbly and uneven than I'd like. I noticed it seemed worse when it was very damp and/or rainy. That immediately made me think plug wires, so I took a spray bottle with water, and sprayed the wires down with it running. Normally if there was a problem with the wires, you'd start hearing a loud snapping or seeing sparks when they got wet. There was no change. So I kinda' gave up and moved on.
Cue a few weeks later, it's wet and drizzly, and the idle is bit more rumbly again. This time, I waited until it was dark out, and popped the hood. I didn't see anything initially, but as my eyes adjusted, I would see little corona flashes, especially where plug wires crossed each other, went near other hoses or were against brackets/metal. I could also put my fingers near/on the plug wires, and see little corona flashes jumping to my fingers (I could not feel any of the sparks, but they were visible). I then sprayed them again with my bottle, and the corona coming of the wires increased quite dramatically. Snapping the throttle created a real light show.
I can't say with 100% certainty that this is the cause of the rumbly idle (new ignition components are not in yet), but it definitely seems like it's a problem, and the wires are on their way out. Like I said, the strangest part is that besides the rumbly idle, the engine otherwise runs great. So this is definitely something worth checking out if your engine seems a bit rumbly, especially if its wet or damp out.
Not just idle. A few years ago I had made a trip to Louisiana and was returning home up I-65 in south Alabama. A heavy storm hit and as I was driving through the rain the 2F began running poorly. I should have allowed it to die but I continued to give it gas. Wrong approach. I blew out the muffler. I was stranded on the side of I-65 with a dead, instead of a dead reliable 2F. I called my son @cruiserinsanity and he was going to make the long drive with a trailer but I was able to restart the 2F after about 15 minutes. I was able to finish the drive without future problems but definitively watched the skies for more storms. Once home I swapped out the wires and cap for a fresh set and have had no other problems with poor running during wet conditions.
Long ago, I had an 87 vw fox. Ran just fine, except on cold, deary rainy days....of course I didn't have an indoor space to work on stuff then, so I didn't bother to try to work on it on those days, the next day was always a sunny, dry day and it ran just fine again. One day happened to be one of those days and at this point, i had enough of it. So in the sleet, freezing rain and rain there I stood with hood open looking for some miracle......and there it was, arcing off a hard fuel line that one spark plug wire draped across. Once i saw it, I could hear it. I ran over to advance or autozone whatever it was and picked a set of plug wires up( that they had in stock, those were the days), and just like that problem solved.
Is this caused by insulation that's been compromised? Like when a plug wire is resting on sharp metal that eventually slices through the insulation?
Or something else?
Agreed, that it’s an excellent idea to do the plug wire check at nite. @Lead Head
