Check Engine Light
We replaced the plugs, wires and distributor. Now the check engine light doesn't even come on when you try to start it. Any suggestions of what it could be? The cruiser won't start at all either.
Check your EFI fuse....dont know what year your truck is though
I blew my EFI fuse once and my CEL wouldn't come on with all the other lights when my key was in the ignition. Truck wouldnt start either, just kept turning over
My only experience with the CEL not coming on is something wrong with the EFI fuse/relay, but I dont see how changing the plugs, distributor and wires could damage anything. The EFI Main that you refer to is the EFI Main Relay which could be broken, but I wouldnt go there yet.
You need to give more information. Is the truck turning over or will it not turn over? Have you done any other recent work to the truck? You double checked the order the plug wires are plugged into the distributor? You double checked the installation of the distributor? What about the rotor? Did you notice a spark at any time while working on it?
Hopefully someone else will chime in here and try and help you out.
Check the fusible links since you are reporting the EFI fuse is good. The MIL (aka CEL) illuminates when the key is turned to the ON position to indicate (among other things) that the main engine ECU is getting power. If the ECU doesn't get power then you are not going anywhere and you are not going to start the engine.
-B-
The truck turns over, just cranks & cranks but will not start. Haven't done any other work to the truck recently. It was running a little rough so we decided to change out the plugs, distributor cap and wires. Checked the order of the plugs, etc. After checking everthing I noticed that the CEL did not come on with all the other lights when we tried to start the truck. There is no spark.
Fusible links??? Where are they located? CEL does not illuminate at all with the other lights on the dash when you turn the ignition switch on. The truck turns over but doesn't attempt to start. Pulled the coil wire off, no spark. Truck was running a little rough, just changed out plugs, wires, cap & rotor, now it won't start at all. Seems like something else is disconnected but don't know where to look.
Fusible links are very easy to find although maybe not easy to explain. If you look in your Toyota Owners Manual it will show you. I'll try to tell you and maybe you can find them. They are located on the positive battery cable just follow the cable from the positive battery post back through the hole in the battery enclosure. When you see the cable go through the hole in the battery enclosure it's just on the other side of the hole. Did I explain well enough?
I really want you to be able to fix this, so I looked in my FSM.
Here are the areas that may prevent your truck from getting combustion in order of probability
1) Distributor
2) Ignition Circuit
3) EFI Main Relay
4) Circuit Opening Relay
5) Volume Air Flow Circuit
6) Fuel Pump
7) Fuel Quality
8) IAC Valve
9) Compression
10) Valve Timing
11) this one is mia in the fsm
12) RPM Signal Circuit
13) ECM
So the top three. You've double, triple, quadruple checked to make sure your distributor is installed correctly? Wires to the plugs, coil, etc...#2 is likely the fusible link that Beowulf mentioned. The fusible link this right behind the battery and is the beginning of the ignition circuit. #3 you say the EFI fuse is ok, so thats probably not it.
Hope this helps
We finally gave up trying to solve our (Lisajo and I) problem with the Land Bruiser and towed into the Toyota dealership today. The service guy just called and says my computer is bad....1900 dollars to install it. I don't really know what to think of that. He said they traced all of the electrical circuits and the ignitor wasn't sending a spark, they swapped it with another from a 95 and still nothing. From this they deduced it is the computer. Has anyone ever had one of these go out and shouldn't they be able to test the one I have without me buying a new one????
I have not heard of a hard failure of the ECM (computer.) The early '93 models have an issue with throwing codes but AFAIK, the ECM still ran the trucks OK when this was a problem.
Swapping is trivial. Tow the vehicle back to your garage, call some breakers and locate one for your year, and swap it yourself. Takes all of 10 minutes and a phillips screwdriver.
-B-
Call around and find a local Japanese car mechanic. Tow it to them and get a second opinion. From everything I've read on here about dealerships they're not always the best repair option.
The dealership called me back today and said the new computer didn't fix my problem, so I don't have to pay for that. I will be sure and post the final results when they figure this thing out...thank you all for your responses, awesome community here!
That is reassuring. You *do* realize that the reason your truck will not start is because the ECM is not getting +12v. That is the main problem and most likely the *only* problem. It is electrical and the dealer should be able to track it down quickly and for much, much less than the $1,900 you were about to pay for the ECM.
-B-
-B-
I got the Land Cruiser back from the dealer a couple weeks ago and it runs perfect again...after paying dearly for a stupid mistake that is. When I was replacing the plugs, the air intake was in the way so I took it all off. Trying to make it eaiser, I decided to remove the MAF sensor plug by the air filter housing....I realized that wasn't a good idea after pulling it about 1/4 of the way out, so I put it back. When I did that, I shorted the MAF sensor directly to ground and destroyed the MAF and the ECM. The dealer finally figured it out after going throug two new ECM's. Thanks again for your advice.
Removing the MAF is a key detail that you didn't tell us. We have seen many cases where someone tried (you can't do it) to remove the MAF sensor plug and created major problems. If we had that information you would have been running weeks ago.
Thanks for coming back to this thread and giving an update. Most of the time people won't do that and we never know what "fixed" the problem
:cheers:
-B-
