Hi,
Thank you for a great forum!
I have a HDJ 100 series with 270 000 on the clock. I just changed the EGR cooler pipe since I found a crack in it last week. After the change, I suddenly discovered that the car accelerated slowly when I accelerated on the highway. I pressed the accelerator and the car shifted down to third and RPM increased as normal, but the power seemed to be less than normal as the speed wasn't picking up. Suddenly after 10 sec whilst still accelerating, the "check engine light" came on.
The light resets when I turn engine off and on again.
Strange thing; when the "check engine light" has illuminated, the car behaves normal. Acceleration is normal from both standstill and using kick down when cruising.
Other observations:
- The car accelerates normally from a standstill
- The car looses power only occasionally when accelerating from cruise speed.
I have done the following:
-Changed air filter and cleaned the O2 sensor
-Changed diesel filter
-Changed oil/filter
-Checked coolant level to be ok. Actually had to refill as it was low.
I have now ordered a device so that I can read the fault codes on the car. Guess I will have it in the mailbox in a few days.
So, to my question. Anyone who can point me in the right direction from this stage?
Thanks
Other observations:
-Changed oil/filter
Thanks
