Check Engine Light Question — '94 LC OBD1
Portland, OR / SW WA
Hi, all!
My check engine light came on a few weeks ago. Over the past few days, the CEL has been going off for a bit, then coming back on at random times. It seems as though when I hit a big bump in the road the CEL will go off. Right now it's currently off.
My question is: Can I still check the CEL codes even if the CEL isn't on at that particular moment? Do the codes save?
Thanks for the help!
No you can’t.
Put a paper clip in the truck, read up on the test. Next time it does it, pull the code.
I will bet it is o2’s or EGR.
Cheers
  • Like
Reactions: mrq
No you can’t.
Cheers
Thanks for the answer! My rig has been idling rough ever since the CEL came on. I wonder if it's related. Any thoughts?
I was guessing that it is an O2 sensor that's making the light go on.
Cross your fingers that it's nothing major!
