check engine light on
greetings all,
I just purchased a 1996 fj 80 with all the bells and whistles. it was extremly clean with 164,000 mile on it when I got it the light for the air bags was on. I was told that the senser needs to be replaced and I got money off the truck to fix it which I have not done yet. I have put about 800 miles on it since I bought it and it runs great with no oil leaks to report. But... today the check engine light went on. I was almost completely out of fuel, no low fuel light. I went to fill ur up and I checked all the fluids (oil, trans and power steering) and everything was good nothing low. What else should I check. can drive it? my truck is in the shop getting some work done so I can't drop it off for a couple of days is it just a computer glich or could there be something wrong.
any suggestions?
Search "CEL" or "Check engine light" or "OBDII Code Reader" and you should get an idea where to start.
Sears sells a reader for under $100, with a manual. Might be a good buy. I think I shall get one.
A good temporary fix is to tilt the steering wheel up more, plus it gives you more leg room. You can still see the reflection of the light in the side window near the mirror, it just isn't shining in your face so much. :)
Post up what you do about that airbag controller. My light has been on for a while and showing a passenger squib code, but the troubleshooting per the FSM points to a bad controller ($$ :frown: ) but since I rarely have passengers, I haven't gotten it fixed yet. Plus, I also don't have collision coverage on my insurance policy so I am trying to just drive safe and not get into an accident. I looked into getting it fixed at a couple of places on the net that charged $75-150 to fix them, but none of them ever got back to me.
Does anyone know if other Toyota's have the same sensor/controller box? I would think they might be the same since the people inside all Toyota's are more or less the same, so the G forces that trigger them should be the same.
It took about 24 gal. of fuel I did not notice a low fuel light. The gauge showed empty.
also I didnt notice a code? just the check engine light. Is this a dumb question do you need a code reader and does auto zone check this for free
Ok; that is almost empty! Tank is 25gal., so yeah, the light might be out.
Light is telling you there are codes to be pulled; yes you nead a reader for your year; yes somewhere like Autozone should do it for free. (Call ahead and verify, of course.)
Curtis
AutoZone will read the code, tell you what it means, and more than likely recommend you to some place that can fix it. They will do it for free.
