Check Engine Light code 170?
Germantown MD
Check engine light came on after I did 2 things:
Put my oxygen sensor back on the studs with new nuts after the nuts backed out.
Checked my air filter.
I had the Check Engine light checked at an AAMCO and the tech said the code thrown was "170, left bank too lean". I remember seeing codes in the FAQ and didn't remember a 170 so I asked him about it. He seemed very anxious to move on to whatever else he was doing and said it was probably bad gas.
I am guessing it is the intake tube that I probably put cracks in after check the air filter but want to make sure.
Does the 170 code actually exist? I need to take care of this soon because I am taking a long road trip this weekend.
TIA
1) O2 sensor can throw a 170; check your re-install wiring?
2) Don't think a cracked air tube usually throws a code, you just need to check very carefully whether it is in fact cracked.
3) *Maybe* the code got triggered just from the act of changing the sensor (like if you started the rig before plugging in the new sensor). In which case just clear the code and see if it comes back.
Curtis
Cracked intake tube on my 94 didn't bring up any codes...just a very rough idle! O2 sensor wiring X2...check the connectors for corrosion.
