Check Engine Light After Wash.
:beer: Hello, New to MUD, GREAT SITE! I have a 96 LX 450 Locked. Today I decided to clean the engine . After I was finished I started it up and it ran ruff in the lower RPM's then after a few moments of this the check engine light came on. Obviously something got wet or maybe unpluged. Looked around and everything appeared to be fine. An hour later I started it up again and everything was back to normal engine running smooth, but the check engine light remains on. Any Ideas would be helpful.
Thanks
It might go away on it's own after a few runs. Others will know much better than i do.
You might want to get a Scan guage for around $50 at an auto parts store. You can clear the code that way yourself. I think everyone should have one at this point in time. It will really help you keep the mechanics honest. There are a lot of things you can fix by just using the guage and buying the part.
You could take it to about any parts store and ask them to scan it for you. You most likely got water into the ignition components (plug wire, plug cup, distributor, coil wire, etc) which set the code as a misfire, then it dried out. The code will remain until it is either reset, or you disconnect the negative battery post for a minute.
If you decide to wash your engine off again first disconnect the battery then cover the distributor cap, the brake reservoir, the dipsticks, and don't point high pressure water at the top of the valve cover where water can get down into the cups that the spark plugs sit in. Also, do it at a time when the rig can sit a few hours at least and dry off before you start it. Watch also that the engine harnesses do not get filled with water. The solid gray plastic covering that is over some of the wires (and open near the connector end) tends to hold water.
Thanks for the advice. I will try to be more careful from now on.
Adrod.
The check engine light was likely triggered by the engine misfire which was the cause of the rough running and low idle. Disconnecting the battery or using a code reader to reset it will clear the light.
One note of caution, be sure you know the security code for the stereo and know how to clear it before disconnecting the battery.
When I wash my engines, I typically will spray Simple Green, let it sit for few minutes, then rinse off with a water hose (not a power washer). But what I also do is to try to blow the engine bay dry using either a shop vacuum or a compressor. I just blow off all the standing water and make an effort to dry off the electrical stuff, distributor, main connectors, fuse boxes etc.
Never had any trouble. No rough running, no code, nothing. Ever. Many different vehicles.
The check engine light was likely triggered by the engine misfire which was the cause of the rough running and low idle. ...
Yep, most often caused by water getting into the distributer. It has three vent holes in the bottom housing where water can get in, causing the miss. The cap can be removed and dried or the water will relatively quickly evaporate fixing the miss. Once the engine is no longer missing, the ECM will reset the code/turn off the light, so no action is needed.
When washing the motor, the easiest way to prevent this is, wrap some shop towels around the base of the distributer, between the distributer and head. The rest of the stuff under the hood is pretty much waterproof from a washing the motor point of view.
