Cheap Ebay HID install
Northern Territory, Australia
Hi All, I've just done an install of an HID conversion, which I bought off Ebay. FYI, You can probably get these kits in the US from China, I'm in the Northern Territory, Australia. This literally only took an hour to complete, with taking pictures. You need good lights up here, with all the potential roadkill around, so while I'm waiting to fit my Super Oscars on, I thought I'd try these. At $50AU a set, if they fail I won't be too disappointed. I chose the 4300K kit which is supposed to be more of a natural white light. They seem to be well made and have quality waterproof connectors fitted.
This is what the kit looks like after you unpack it. I have connected some of the wires together already on the one on the right.
This kit didn't come in a box, perhaps the same kit is used by more expensive brand name companies? If you want a box you have to pay US$10-15 extra
The instructions are in English, obviously converted from Chinese, but I doubt you will even need them anyway. I've tried to make this install as simple as possible so that if they do **** themselves you can just replace the original globes easily.
The first thing you need to do is remove the original high beam globes. I wouldn't fit these to the low beam side as they are way too bright and most probably would attract the attention of the law or at the least, **** off every other motorist who happens to be in front of you!
The high beam globes are the inner of the pair and you have to remove the harness connector, then a rubber cover (Which can be a pain to get off) and then an adaptor, which will probably come off with the cover. If it does, take it out and keep it. Next, take out the H1 halogen globe by pushing in the retaining clip at the bottom and then pushing the clip in a downward motion. Take care not to touch the glass and you can put it in a zip-lock bag with the adaptor and keep it in your glovebox for an emergency (If the HID lights stop working one day). Edit: You can re-use the protective container that the HID globes come in as seen above.
Original, dirty, High Beam Globe connector.
H1 Globe adaptor (On Right) and Rubber cover.
And, the H1 globe removed...Keep this and the adaptor.
Next, we have to remove this rubber moulded grommet that comes with the kit. The kit is designed to kit many different models of car and mentions in the instructions to drill a 25mm hole into the back of the light assembly so you can use this rubber grommet. I didn't want to do this obviously, so will be using the original Landcruiser rubber cover instead.
HID harness with moulded on rubber grommet.
And here it is removed with the help of a Stanley knife (Please be careful not to cut yourself!)
Now, you will notice that the retaining clip for the H1 globe is slightly too small to allow the largest of the two connectors to go through the centre, which it needs to do. I just bent the inner edges out with a pair of pliers, just enough to get the connectors through. Then re-bend them back into shape. The metal is pretty easy to work with. You could probably file out the hole a bit bigger instead but by doing this you risk the globe not being held in the socket as well.
The largest of the two connectors (on the left) has to be able to go through the centre of the globe retaining clip. I just bent the inner edges outwards.
And here is the harness with the globe retaining clip on
Now we need to carefully remove the protective cover that is over the HID light and put the HID globe in where the original halogen was. Pretty simple, but you will find you have to put the retaining clip on first, then feed then globe and wires through, then clip the retainer on as the HID globe is a bit longer due to the wiring.
This is what the HID globe looks like. The correct way to fit it is how I am holding it. With the brass coloured wire upwards
Next, we have to get the original rubber cover over those two connectors. I just cut two slots with a knife down from the 'dummy' slot, which will open it up enough to put the connectors through. Now poke the connectors through the slot and put the cover back over the light assembly. If you are worried about water getting in, you could always put some silastic around the wires where they come through the rubber. I didn't bother.
Cut downwards with your knife towards the centre from the 'dummy' (Top, horizontal) slot. One cut may be enough
And here you can see I have poked the wires through the resulting 'flap'
Now you just have to connect the ballast connectors to the HID globe connectors (You can't get it wrong, they are male/female).
The next step is to put the bracket on to the HID ballast, pretty simple. You could also stick it to a panel if you wanted with some double-sided tape or silastic which would work just as well. I've got pretty limited room around that area with the coolant reservoir back, in so I decided to mount it to the radiator. I just bent up the bracket and opened up the top hole a bit to allow the bolt to go through.
Bracket mounted to the HID ballast and bent to shape
Next, get out your test light or multimeter and find the positive wire on the connector. Using a test light, put the high beam lights on and connect your alligator clip to an earth and probe the connector. On mine, the wire with the stripe is the positive. Connect the harness with the red (Positive) and black (Earth) wires into the Ballast box. Now just push those spade ends into the connector. I just taped up the connector and wires to stop dust and water from getting in but you could use some large heat shrink to do the same job but a bit neater. Also, if you are wanting to make this a bit more permanent, you could take out the female spade connectors from the holder and connect them that way. For even more permanent installations, you could just cut out the connector all together and crimp on some corresponding female spades to join them. The problem with doing this is if the HID's **** out you can't easily refit your original halogen globes.
This is the original Toyota connector with the positive and negative wires from the ballast installed and the whole lot taped up
Then I just mounted the Ballast box onto the radiator using one of the bolts. If you have more room than me, there is probably enough wire length to mount the box next to the battery. I don't as I have all the wiring for the hydraulic winch there.
Ballast box mounted on Drivers Side
Ballast box mounted on Passengers Side
This is what it looks like with just one HID installed on the passengers side. Hard to see but trust me there is a big difference in both brightness and colour
And with both installed. The camera doesn't really pick up the huge increase in light output present with the HID kit installed
So far I am very happy with the output from the HEI kit, the difference is quite amazing compared to the original high beam. Time will tell whether they last as long but if they don't I can always change them back easily to the original globes.
I got something else from Ebay in the mail this morning, a single DIN CD holder/cup holder from China. It was $25 plus $7 postage and does a good job of filling in that gap left after a single DIN CD player is installed.
Pioneer CD/MP3 with Ipod control
CD holders, x3
Cup holders, x2
Thanks for the write up!
Are you satisfied with ther performance of the outer light (H4: low/high, right?:confused:)
I've heard people doing the HID on the outer light and just have them fixed at/to lowbeams.
I guess you guys probably get to use the high beams for extended periods of time for the system to warm up, eh?
BTW, do you think mounting the ballasts on the side of the radiator would cause them to heat up excessively and potentially fail (prematurely???)
Anyway, thanks again for the write up and welcome aboard! (:flipoff2:)
Mot (from Japan)
Our lights have low beam on the outer two and high beam on the inner two, so I just fitted them to replace the inner high beam. They only take a fraction of a second to come on, so I'm not sure about them having to warm up. I did think about the radiator getting hot but I really don't have any place better to mount them. Hopefully the air coming from the front going across the ballast would be sufficient to cool them. We will see.
For the cup holder/cd rack, try this store:
eBay Australia Shop - Selco Audio: Car Audio Accessories
I'm sure there's a heap out there that sell them
Rick,
If heating them up ever becomes an issue, I've seen people mount things (such as an oil cooler behind one of the corner markers by "photoman"), if there's no other place to mount them.
Keep us posted on the night performance with pics, as well as the longevity of all of the components.
Enjoy!
OK, so it's now dark, so I went outside and took some pics:
Here you can see the 'whiter' look of the HID lights
This is on low beam:
This is on high beam:
I think they may warm up after a few seconds, cos the next pic I took, the camera didn't like too much:
And the Rangie on low and high for comparison
Low Beam
High Beam
I tried to get a photo with the Rangie's spotlights on (Cibie Oscars) but the camera didn't like it:
By Rick269
I'll let you all know how they perform on the road.
Thanks for the pics, Rick!
I hope your camera will like you when you decide to take additional pictures, like on-board/in-cabin pictures in the outback or something! ;)
Nice one Rick, this is something I'm keen to do too. At that price it doesn't really matter if they don't last very long! :)
Have you got link or name for the kit you bought?
Like this one?
This is The Olgas, a group of rock formations near Ayers Rock. I took this from on top of the roof rack on my GQ a few years ago.
And this is a sandstorm we ran into, also on the same trip.
You'll have to wait until I go on my next trip for more pics...
Can you provide the name of the seller or kit you purchased on e-bay please?
Like this one?
Rick,
Thanks for the links!
How about some pics of how the lights perform from the driver's perspective at night on a long, dark stretch of road, or on your way down to a local grocery store? :hillbilly:
I had heard that those quad lights did perform rather poorly, but the difference, at least from what I can see from the pics, appears significant.
And with you using them for high beams you don't really have to worry about blinding on-coming traffic (anymore than you would with the halogens) since you would only be using them when there are no on-coming traffic. ;)
I thought about doing this. How's the view at night ? I was also looking for H4 low halo/high xenon for the outers but have not found that yet. That way, low beam is just low halo, high beam is double HID which should be awesome !
Hi Dutchie, The view is so good at night, I honestly don't need to use the spotlights. The light output is very white and clear and 100 times better than the yellow glow from the original high beams (and low's for that matter). However, I wouldn't fit them to the low beams as it would certainly blind people coming towards you they are so bright. It's the best mod I've done to my Cruiser honestly and even with my less-than-perfect quick install they are still holding together perfectly.
Thanks mate!
Just ordered a set of H1's 50w digital 4300K to go in to the inner highs. Hopefully next week result. I never wanted HID low, just was looking for possibility of a light that does low halo and high HID, that would be nice.
Making a complete new headlight/spotlight loom now so I can upgrade the outer std 60/55 to something better (100/90 or 130/90 halo's) as I really need some better light on lows, it's very poor (used to projector lights in a late model Volvo S40... bit better :) )
