Cheap and easy rear camera
CO Springs
Here's a quick how-to for a back-up camera for $34-$39, depending on which monitor you use.
I bought an E363 rear camera from Amazon. Current cost is less than $15 shipped for the camera. Add to that a monitor. I initially bought a 3.5 inch monitor for $19. However it arrived DOA, so on a whim I had them send me a 4.3 inch model for $24. The overall size of the two monitors are roughly equal - one just has a larger border frame. They are made by the same company and also sold under the Taotronic brand. I do not think the 4.3 incher is necessarily any better quality than the 3.5 incher. I think the first monitor had been damaged in shipping.
http://i8.photobucket.com/albums/a17/docmallory/IMG_8415.jpg
I started by installing the camera. I used a handy tool I got off eBay to pop all the clips on the tailgate carpet without breaking any.
http://i8.photobucket.com/albums/a17/docmallory/IMG_8428.jpg
Then I removed the little panel to access the back of the license light holder. The light holder is held in by 3 nuts. Remove the nuts and the holder comes right off.
http://i8.photobucket.com/albums/a17/docmallory/IMG_8430.jpg
There is a rubber grommet where the license light wires pass into the tailgate. I pushed the grommet through, inserted the wiring for the camera, and then made a slit in the grommet so I could reinstall it around the camera wires.
http://i8.photobucket.com/albums/a17/docmallory/IMG_8431.jpg
The plan was to install the camera on the bottom of the license light holder, in-between the two lights. I used a dremel to make a small notch for the wiring to enter the holder from the camera.
http://i8.photobucket.com/albums/a17/docmallory/IMG_8432.jpg
Then I drilled two holes in the plastic holder to mount the camera. Note that I painted the camera with Plasti-Dip for two reasons - one was to make it less noticeable, and the other was to hopefully help prevent water from entering the camera.
http://i8.photobucket.com/albums/a17/docmallory/IMG_8435.jpg
I used some small nuts and bolts from my odds and ends collection to mount it, rather than the two small screws that were included in the kit.
http://i8.photobucket.com/albums/a17/docmallory/IMG_8436.jpg
The next step was connecting the long video cable and the power cable to the connectors inside the tailgate. To do this, I started at the rubber wire loom that runs between the tailgate and the body. I pulled the loom away from the body, and pushed the video cable and then the power cable up through the rubber loom. I did not get a photo of this, but it was surprisingly *the hardest part of this project*. The rubber tube is just BARELY big enough to squeeze the video connector through. If I had to do it again, I would trim the connector of the video cable to make it smaller in diameter. It took 15 minutes of pushing on the connector to squeeze it through the tube. Then I pushed the video and power connectors up into the tailgate, connected them to the camera cables and then wrapped them in some foam to prevent rattles.
At the other end of the cables, I pushed them into the truck body where the license light wires enter through the wiring loom. The wires then pass THROUGH a 4 inch deep section of the body and then exit under the truck by the spare tire. I had to tape the wires to a stiff wire to thread them into the hole on the other side. The photo below shows the wires exiting by the spare, where there is a rubber grommet that can be slit to accommodate the wires.
http://i8.photobucket.com/albums/a17/docmallory/IMG_8440.jpg
The power wires are not long enough, so I had to solder on some additional wire and used some heat-shrink on it. I ran the power wires through a plastic corrugated wiring loom (purchased separately) up to a rubber grommet under the jack (where the sunroof drain exits under the truck.) I then used the stiff wire to push the power wires into the jack compartment. From there I ran them to a ground point and to the wiring of the reverse bulb on the driver’s side tail lamp housing. You have to remove the housing to access the wiring, but it’s super easy.
The video cable was run along the frame up to a grommet that is just under the driver’s kick panel (where the pin 7 mod is done and where all the alarm wiring connects to the truck.) Take the screw out of the footrest, remove the footrest, and then pull up the clips on the driver’s threshold cover. The photo below shows the video cable entering the footwell. The black wire at the tip of my finger is the video cable.
http://i8.photobucket.com/albums/a17/docmallory/IMG_8460.jpg
This completes the camera portion of the installation. It’s right in the center of my license plate, but did not photograph well. Notice I removed my license frame. I had installed the camera so far back that I could not adjust it downward enough without hitting the frame.
http://i8.photobucket.com/albums/a17/docmallory/IMG_8469.jpg
To install the monitor, you have to remove the driver’s side grab handle and the visor. Unclip the wiring to the visor. Now would be a good time to check your visor mount for cracks. Both of mine were cracked and I bolstered them by filling the back of the mounts with epoxy. Pull the A-pillar trim away from its snaps. You do NOT have to remove the little holder for the lateral end of the visor - just the main swivel mount.
I also pulled away the rubber trim from around the door, from the footwell up to the top rear of the driver’s door. There is no need to remove it further. I pulled the plastic plugs out of the oh-s### handle area above the driver’s head.
Lastly, I pulled the rubber moulding from the edge of the headliner around the driver’sside of the sunroof. Only do the driver’s side. At this point you can tug the driver’s side of the headliner down enough to easily run your wires.
I unscrewed the single screw holding the center cover on the sunroof control, then popped that cover off. I then removed the two large screws to totally remove the control panel. It is held in place by some wiring. Just scrape off some of the old crusty foam padding, insert a flat screwdriver under the clip, pry up and it should separate easily. I painted my outer control panel with Plasti-Dip because it was kinda yellow-looking and did not match my grey interior well. I then installed the mount for the monitor upside down onto the back of the panel trim using two bolts. It did not show well in the photos.
Next you can run the wiring from the monitor across the headliner to the A-pillar and down toward the fuse box. The video cable was plenty long for this, but I did need to add some additional wire to the power supply for the monitor. Note that there will be connectors now located above the diver’s visor, and I wrapped these in foam to prevent rattles. The monitor has a power cable and two video cables (white, yellow). Connect the camera to the WHITE input of the monitor and leave the yellow disconnected, unless you are going to run another video source to the monitor (like a DVD player or another camera). Connect the power wire to an accessory or ignition switched source and ground the black wire.
The monitor will get power when the truck is on, but it will not show any image until it gets a video source from the camera.
The little square in the bottom center of the video picture is my receiver hitch.
This mod would likely go great with one of those rearview mirrors with the built-in monitor. I considered that route but was afraid the optics of the monitor/mirror might not be good. I was also thinking I might mount the monitor somewhere on the center console, but it turns out the overhead console was super easy.
Some of the newer lexus cars come with a monitor inside the rearview mirror. They're very tiny and hard to see. Your 4.3" monitor looks much better.
I wonder if my gps has video input. Hmmmm...
I installed a similar camera this fall -- you didn't have to make that notch. If you notice, the license plate light housings - although themselves sealed - are not sealed to the light holder completely. There is a little gap on the inside corner of each one.
At least there was on my '94. I just took out a light, pushed the wiring through, and put the light back in.
Brad, that was an outstanding write up, thanks for taking the time (and all the photos). I've been looking at the Taotronics setup on Amazon for several months now, intending to get them for both my wife's Pilot and my LC, so this write up was timely and helpful. Another "To Do" for the vehicles!
Thanks
Paul
Thanks for the write up but I have a newbie question: how did you wire the monitor to the ignition? Any pictures of that?
Thanks
Did the same mount except I did put the monitor on the center console. I use mine only for reverse. I wired it to the reverse lights.
Thanks
The easiest way for a newbie is to use a circuit tester to find a fuse that is powered with the ignition (like the fuse for the power windows, for example). Then use an "add a fuse" kit like THIS to connect the monitor's power wire.
Ah very interesting. Is there an ignition fuse box by the foot well? I know there is a fuse panel by my left knee. Also I just ground it to the frame right?
Just ordered a version with monitor/mirror combo and wireless camera so I con't have to run the wire, all I need is power source for the monitor/mirror. Will post pictures if it is as good as I hope it would be.
There's just the one by your left knee. You'll have to snake the wire up from under the dash to the fuse box, but it's not hard. I use a stiff wire for that. I ground things to the body by finding existing bolts that are screwed into the metal part of the body.
Thanks for the info and I ended up running the wire down the pillar to the fuse box. The camera takes a bout 4 seconds to come up but it works great!
