Cheap 4x2 conversion.
Asturias(Spain)-London(England)
Website
www.sybaris-expediciones.com
I took a look at the slee part-time kit: Slee - Drivetrain - Drive Shafts
It looks interesting, but it's not available where I live. What I can source are the AVM free wheel hubs, at a very good price by the way.
I know that slee's kit is much better as you disconnect from the central diff, but, what if you just installed the AVM hubs and disconnect them when you want 4x2? Locking the central diff, off course.
The front driveshaft, differential and axle shaft would still be moving, but, not being connected to the tires, do you think it'd improve fuel economy and power?.
Also, even though the front drivetrain is still moving, it's not under the same torsion forces it'd be if connected to the tires, is it?. So it would wear slowly.
Do you think it could be a good idea or just a waste of money and time?
I've read in a few threads on this forum that those who have done the conversion only see a ~5% increase in gas milage. Less wear on parts though, I suppose.
It's probably not worth doing just the hubs. You would probably end up wearing out your spindles since the CV stub would be spinning inside.
I think it would be entirely worthwhile if you drop the front driveshaft when you are not using it.
