chassis repair
Good day,
I owned a bj40. which, recently I have found a crack on its chassis in front where the hanger was welded and another one in the mid section of the chassis.
I have welded both cracks and on top of each crack i fully weld a metal plate.
Can someone please enlighten me if what I have done can retain the integrity of my chassis or is it better to replace the chassis.
thank you and regards,
pol
Welcome.
Pictures please.
My frame has cracked and been welded on many times.....these things happen to vehicles being operated outside of the original design peramiters.... ;)
Lets see what you did, and go from there..
:beer:
reinforcement plates added to both rear framerails on mine, at least 8 years ago.
Still going strong.
I hope to change frames at some point, but I have no idea when that will be.
thanks to does who replied and gave their ideas and experience about the subject title. atleast now i have more confident on the integrity of my bj40 chassis. I also have problem about my steering (wandering and being sloppy) but I have already read enough on this forum the any questions the I will ask will be just a repetitions of what have already discuss.
once again thank you for your valuable information.
pol
It comes down to your welds. I'd be sure and box the other side of any area that cracked too, regardless of hw good your welds were in the repair area. Probably 6 to 8 inches on each side of the crack with 3/16 - 1/4 flatstock.
Thank you for the advise, it is a sound idea to box the other side of the crack.
One of the plan I have is to use a channel bar (some call it C bar) 3/16 or 1/4 and fix it underneath the entire lenght of the chassis.
The only concern of mine is the weight of this bar that my 40 will be carrying all its life and can it really increase the strenght of the chassis (does the weight of the C bar can affect the fuel consuption dramatically due to the added weight of the C bar). Can anyboby advise me properly before I do something stupid.
regards to all,
pol
i'm restoring a frame .... i'm not sure if its the same in the BJ but my fJ has an outter C-channel and an inner C-channel which are riveted together with "hot" rivets. I took the time and welded the inner to the outter. The plan was to improve rigidy and thus not causing as much stress to the other parts of the chassis. near the end of the frame i will box it in with 3/16's inch plate... if your welding or boxing in the frame with re-inforcement plates i would suggest to cut the plates so there shaped like < > on the ends or a / /. there has been a couple discussions on the hardcore forum about using just a rectangle to box them in and its not as structurely strong. I Wouldn't use 1/4 i really don't think it needs that thick of steel. I really doubt adding a few extra pounds will affect fuel consumption....these rigs are farely heavy to begin with and not at all aerodynamic.
