Chassis Lubrication points..
Calgary, AB
Just wondering of there is some sort of list or drawing for the chassis lubrication points on an 80? I have an HDJ81 but I think it shares a lot with a North American 80. FSM says nothing about the topic, unless I missed it somehow..
Also, what type of grease you guys would recommend..
Cheers,
A.
No owner's manual unfortunately. The one I have is in Japanese and it doesn't seem to have any drawing for lubrication. Is there a site online where I may find an owner manual for an 80?
On the 80, all the grease points that I remember are on the driveshafts. So if you lube 4 U joints and 2 slip yokes, you've got it. They take lithium based chassis grease #2. You can also bube the steering knuckles through the grease port-that takes moly lithium based grease. If you make it a habit to lube the driveshafts with eachoil change, you'll likely never have any problems.
Thanks Andrew...
Great info...Good idea to do it with each oil change. Won't take long and just a peace of mind..
I saw what seems to be a trace of red grease around the birfield joints. Is there supposed to be a grease point there too??
:cheers:
