Chasing low idle—direction appreciated
Pacific Northwest
So on occasion she drops down to about 300 or 400—rest of the time she happily idles between 6.25-6.5. Could this be caused by an exhaust leak or plugged catalytic converter?—the floor gets crazy hot on the freeway. Also the pair valve has been removed but block off plates have been installed along with capping the vacuum hose. Here is what I have done so far……. Also planning on a head gasket job in the next few weeks and would like to get this resolved. 94 Cruiser with 163k U.S. model.
So far:
Replaced cap and rotor
Measured plug wires and all are in spec according to FSM
Cleaned throttle body, MAF
Inspected air tube—its only a year old
Washed air filter
Checked TPS against fsm
Replaced all vacuum hoses to guard against possible vacuum leaks
Replaced PCV valve and grommet
Replaced Spark plugs
Replaced EGR Modulator
Checked both batteries to assure connections—both are grounded to engine and sheet metal
Opened up wire harness by egr and Inspected numerous times--I have a ax handle to push on them--can't get anything to stumble
Opened up wire harness in engine bay going to glove box…….
Tried the Diagnostic trouble code detection for Oxygen sensors
Again the diagnostic stuff for the Air-fuel ratio
And Again for the EGR system
Sprayed electrical cleaner in between all connectors like tps an such
In the mail from Dan—planning with head gasket pm
New fuel filter (power is fine at higher rpm… PM)
New fuel pump ( again PM)
New fuel pressure regulator
Also planning on changing the fuel sock as PM
Adjusting valves as PM
Cleaning fuel rail and injectors as PM
Have you changed your brand of fuel recently? Maybe try some type of fuel additive (Chevron Tectron, Redline, Seafoam... I will let you decide).
From you list of things you have checked, that is the only thing that comes to mind.
Good luck with the headgasket job!
Riley
The one thing I don't think you have mentioned is the IACV it controls idle along with the TPS. It's a $365 part..... CDan also told me to look at the throttle cable and make sure it isn't sticking.. BTW I have the exact same issue with my 94. Do you notice that your low idle occurs all times or just with the AC on when the compressor cycles off?
I ran a bottle of Techron, and 2 seafoam treatments and it didn't help. Then again I don't have the idle miss that others have..
Riley
I live in Mexico and there is only one brand of gas---Pemex(state owned)....I do run premium--and I have been using injector cleaner and redline that I picked up in the U.S.--things are smoother but still no dice. Upon cold start up it almost always has loss of power.
I will test the IACV tonight. I just replaced the Accelerator cable and adjusted the throttle cable upon these issues--all in in spec of the fsm--will try a bit of graphite tonight. I have noticed the A/C helps keep it up when it drops!--but it will idle low without the A/C as well....
$365 sounds bad until you compare it to say a new double cab Tundra 5.7 4x4--with the 0% promo it is still $500 a month for 5 years.......
