I’ve been having charging issues for a few weeks now and I think I’ve finally figured out the problem after replacing the alternator, battery, fusible link, and battery cables. It looks to be an issue with the B+ terminal wiring. I noticed a loose wire in the loom, and it turned out the wire going to the B+ terminal was completely seared off. It looked like the PO tried using a butt crimp on it at one point for some reason and that finally failed. Soldered the wire back together, but the battery was still reading around 12.5 volts when running. I removed some tape that was around the wires, and found this connection with another wire to nowhere. The loose wire is coming from a loom with a bunch of other wires. The wire I resoldered to the B+ wire is coming from the fusible link. Should this wire be connected to the B+ terminal wire too? The car is a 1984.
