I noticed that on my '92 FJ80 my the charge light doesn't glow when the key is in ACC or cranking the engine. I checked the charge fuse and the charge relay in the fuse block (engine area) and everything is fine. I ended up in the white/yellow wire from the plug in the alternator (there are three cables there). I even checked the bulb in the cluster and is fine also.
Is that light suppose to glow when the key is on ACC and when the engine is cranking?
What about the A/T temp light, is that light suppose to come on also when starting the engine?
