charcoal canister hose part numbers
Ok so nada on how to replace 23273-66031 and 77795-60020 … after staring at this I’m thinking I’d have to remove the abs pump to gain access. Anyone has tips or tricks on how to replace the bottom hose for the charcoal canister??
Assuming this is the OEM canister bottom hose...remove the canister? I'm probably not tracking exactly what you mean. It's how I replaced mine.
Trying to remove this hose, my thumb slipped and lost some blood. This hose was on there TIGHT. I had to loosen it with a pick at first before attempting to pull it down. There was some gasoline in this line. Guess that’s why you replace it with 23273-66031 Hose, Fuel No. 2
the last hose : 77795-60020 lives under the canister , I’ll have to get to it in a few
Confirmed the placement of these 2 hoses, will sort out how the other 2 are placed and post a pic back, thanks yal
Confirmed the placement of these 2 hoses, will sort out how the other 2 are placed and post a pic back, thanks yall
Right above the red text that says 77279-60180 .. right above the "0" in 601 there is a small hose, about 1.5" olng. I cannot seem to find it anywhere. Looks like this ...
You can cut off a piece from 77754-60180 and put it there. When you have the hose in your hand and you see how long it it is, you will discover it’s 1.5 inches longer than it should be. That’s where you get that 1.5 inch hose from
Ya know, last night after my son and I finished it, I had the same thought! :) I'm on it now!
Thank you so much for this post. It has been incredibly helpful!
There’s also another small hose near this cut off 1.5 inch hose, which I would like to replace as well.
By any chance, does anyone know what part number it might be? Also, any experience on replacing it?
Thanks!
