Changing the Tcase fluid
Opelika, AL
Yesterday, I planned on taking the rear driveshaft out, getting new u-joints put in, and hand greasing the splines. First off, I couldn't get the d*mn bolts off. I had a set of GearWrench's that were about to round off the nut. (I specifically got those wrenches for my birthday for that job). So my dad tells me he has a friend down the road that has a shop. I take my truck down there to get him to take it off. Well it comes up that he'll put the U-joints in for me too. So I say what the hay and do that and change the transfer case fluid while you're at it. Well today when I went to get it I noticed the TC was leaking from both the fill and drain plug. Now I need to fix this myself like I should have done to start with but I got lazy.:doh:
I believe that I read before to change the washers/gasket/seals, whatever they are, on the drain and fill plugs whenever you change the fluid. My plan to keep the TC fluid that I have in there is to park front end facing down a large terrace at my parents house while I put the new washers/seals/gaskets on the plugs. Anybody see anything wrong with this or a better suggestion? Should this work?
I think you can do it without any vehicular acrobatics. Park on a level surface. Remove the drain plug and quickly stop the drain hole in the tcase with a thumb. Put a gasket on the drain plug and replace in tcase. You could hand the plug to a friend if you don't think you can do it one handed. Then do the fill plug, but without the thumb block. You're only supposed to fill to the bottom of the fill hole you can just let any run out while adding a gasket to the plug.
Catch the fluid in a bucket or drain pan, change out your gaskets, and replace the fluid.
Something feels like it's binding up again. I thought it was my driveshaft but the mechanic I was refered to (see first post) greased my driveshaft for me which seemed to help. I was going to do it myself but he had already did it before I called him. Anyway it felt like the work he did solved the minor thuds I feel after stop and take off. I took the zirk off to release any excess grease out but none came out. Then I left the zirk out and did a few quick stop and go's to push any out. I don't think any came out but that is almost impossible to tell unless I had a camera under there. (I didn't see any slung under my truck either). My question is since I don't want to take this driveshaft off again how can I make sure the right amount is in there and make sure that I don't do any damage to my TC?
Will an over filled Tcase leak at the drain and fill due to pressure?
I got under there today to drain it but before I did I decided to check where the oil level was now that the Tcase has apparently stopped leaking. I was a little afraid it was going to be empty but when I opened the fill plug some drained out. This meant it had to be a good bit overfilled since it's been leaking for a few days - 1 week now.
it will expand when warm, this could have been the issue, he might have filled it to the bottom of the fill hole and when you drove it home warmed up thinned out and leaked a bit out, remember a little bit of warm oil will look like an oil slick under your rig
