Changing main gasket
Do you replace the bolts when you change main (top) gasket in your LJ70 engine? Where do you get those bolts if that is the case and to what price?? 18 bolts could be very expensive..:censor:
light_duty said:
Yes, you should replace the bolts or you won't get the correct torque when you tighten the head down.
Mine cost me about $90 (Canadian Dollars) for the set.
In Norway they are close to 180 US$ for the set, that is pretty expensive and that is why I am asking,:)
