Challenge for Repair Enthusiasts ....1997 Toyota Prado (colorado)
Hi I'm Eric
I have a 1997 Toyota Prado VX 5 door
Engine : 5VZ-FE, 3378cc, (gasoline)petrol, V6, efi
Problem : Hard Starting
When i start it up the engine will crank but it will not start, then i will try it a couple
of times eventually the engine will start.... then when i turn it off for just 20 minutes,
it'll have a hard time starting again. If I turn it off and on within 20 mins it will run
fine....and take note, the check engine indicator is not lit.
The solutions I have done:
1. I thought it was the starter-I bought a new one
2. I also had the oil changed and replaced the-spark plugs, fuel filter, fuel pump,
air filter and high tension wires
3. I drove it to a Toyota Service center-since the check engine indicator is not lit, they
cant diagnose it, because the car wasnt sending any OBDII codes. Instead they checked the
engine compression, and found out it was fine.
Hope to Hear...h
Hi I'm Eric
Hope to Hear...h
