So, just redid the centre arm and all the tie rods, put it all together fairly greased up, and tightened (the centre arm) as per the factory manual, it seems to get loose the first few times I've driven it though - is this normal and just due to the grease squeezing out and the thing 'working itself in'? Also - if I still see some slop there, I gather that it is likely because the actual bracket is goobered - where is the best place in or near the lower mainland to get a replacement? SOR price is about 100, toyota wanted ~180? (the gearbox still holds oil and doesn't seem to have any slop, the draglink where the pitman arm comes in is still within adjustment range and is adjusted properly, I think the only places left I could get clop coming in are the centre arm and the rag joint?)
Thanks!
Evan
Thanks!
Evan
