I just installed the trail gear 2wd spool and 3.11 gears. Everything went smooth with the install. Gears work great but I can’t seem to lock the cdl. It was working before I installed the spool perfectly with the 7 pin mod.
I can hear the relay and the motor move when I press the cdl button and the only light that comes on is the abs, doesn’t come on right away but after 5 seconds of moving because of the Asian hubs unlocked. I was running in 2wd before the install by leaving the hubs unlocked and locking the cdl before the spool install. So now when I start the LC on the light tree the CDL light doesn’t even light up either. I’m stuck in 2wd. Please help.
The only thing I can think of is that when removing the actuator the big gear came out. Upon reinstallation I pulled the pin that the big gear moves out of its original position then reinstalled the actuator.
Do I need to remove the actuator again and move the gear in a fully closed or open position? Would that really matter?
Has anyone encountered this issue?
