Center Diff Question
Arizona
I enganged my center diff last night (on dirt). To exercise it like I have read here. Should me Center Diff Light turn on whenever I engage the 4lL? Meaning I move the small shifter from 4H to 4L. Is this right? I didnt know it engaged right away.
Locks in HI using the switch on the dash (standard on a 91-92). Automatically locks when put into LO, although there is an easy modification to change this. If you perform the mod, then the dash switch is used to activate the CDL both in HI and in LO. (Thus giving you the option of open center diff. LO.)
Curtis
What is the advatage of having the option?
Think about it. You said you went in dirt last night to exercise your center diff thus putting it in true 4WD right? Well if you do the mod CJF is talking about then you could put your truck in 4LO on the street as long as you don't push the Center diff button.
Now why you would want to do this? Advantage could be you could put it in 4LO without being in true 4WD. It's fun to see how capably your truck is in all wheel drive with lower gearing. Are you going to do that very much... maybe not, but it's nice to have. I think mostly because alot of people are used to this from the old 4wd world; trucks with locking hubs. If the hubs aren't locked you can put it in 4WD LO just for the benefit of gearing.
Search for the pin mod CJF is talking about. Haven't done it myself yet either.
Neither have I.
BTW, AFAIK (how's that for acronymania:D) it's not a pin mod on a 91-92; just unplug a sensor from the T-case. Or maybe the 7-pin mod for later years works on a 91-92 as well? :meh: (<--- been wantin' to use that guy. :lol:)
Curtis
Yep, it does. I did the pin 7 mod on my 80 several months ago... I LOVE it. Use LO all the time now :biggrin:
MAN!!!! I have so much to learn......
