Center diff lock switch
Arizona
I have a 1994 80. Bought the center diff lock switch and tried to install. I cannot locate the wiring plug for switch. I was told it would be behind the dash. Anyone have the same issue?.
It’s back there... it has a jumper plugged in the connector. Usually wrapped in gray foam with a yellow jumper wire. Gotta unplug the jumper and connect the switch.
Look for this. It needs to be unplugged from the connector. The switch then plugs into the harness connector...
:cheers:
No problem... Glad you found it!
Now do the pin 7 mod!!
Slee - Pin 7 Mod for CDL (Toyota 80 Series Land Cruiser)
In a nutshell...
The cdl switch will allow you to lock the center diff in high range. The center diff will still automatically lock when the tcase is put in low range. Performing the pin 7 mod and having a cdl switch will allow you to lock and unlock the center diff in high and low range, it will no longer automatically lock. AND if you have diff locks, you can use them in high range...
