Center Diff Lock stuck on
Rotorua, New Zealand
Hi all,
Yes another CDL thread. I have researched many threads on here, so I've done my homework before asking.
After a weekend of 4x4 on the muddy east coast North Island New Zealand with lots of blasting up and down rivers, my CDL wont disengage.
Never happened before. Its a dedicated 4x4 rig and gets a regular workout.
1995 HDJ81 factory CDL and ARB lockers.
- I've cycled the Low high lever a hundred times.
- Drove backwards, forwards, circles, kerbs etc.
- Had to drive 200kms home from event with it stuck in - yes its defiantly stuck in not just the light, the grinding and clunking tells me so.
- I can hear the relay clicking when changing from high to low.
- fuse is fine
- I removed the actuator and it moves freely with my finger.
I'm not electrically minded so im unsure where to go from here.
Any help much appreciated.
Use a 9v battery to see if the actuator motor works. There's a thread somewhere that shows what pins to jump.
Make sure the white jumper plug where the CDL switch plugs in is still there(part of the 7pin mod). If it comes out the CDL won't disengage.
The switch next to the actuator...clean the connections; hit it with a hammer (out of the vehicle) on one of the 6 sides where a wrench would touch.
The switch next to the actuator is only to control the dash light and disable ABS. It has no impact on the control of the CDL itself. he OP has confirmed the actuator remains locked.
