center diff lock issue
Hi,
So on my 97 Lx450 the center diff lock feels like it's engaged at all times even though nothing on the dash indicates ( no diff lock and abs light ). I know center diff is locked specially in tight turns when the truck hardly wants to move and I can hear the tires rubbing the pavement.
has anyone had a similar issue to this? How can i disengage the center diff lock?
thanks
With the engine off turn the key on. Shift into low do you breifly here any relays clicking or other noises? Have you ever seen the dash lights work? Have you added a CDL dash switch and if so done the pin 7 mod?
If none of this happens go underneath and pull the connector off the rear of the transfer case at the 1 o'clock position looking forward and short the pins together on the wire harness. Then turn the key on a see if you here the relays or other noises. If still no dash lights remove the short on the connector and take a test drive. Make sure that loose wire doesn't get tangled up in the drive shaft. Report back the results.
