>> as a practical matter, the K292 cannot be upgraded with the OEM solenoid.
This does not mean it cannot be done, just that it isn't very practical. Have a look at this write-up (thanks Christo, as always, for your tech articles).
Slee - Retrofitting Lockers (Toyota 80 Series Land Cruiser)
>> The E lockers only work in low range still right?
I think you understand this, but just for clarification...
In a stock truck, the order of locking is 1) center diff, 2) rear diff locker, 3) front diff locker. That's the only way it works. So, in a stock truck, since you must be in low-range to lock the center diff, then your statement is correct.
However, one of the reasons for the CDL (center diff locker) switch mod, is to allow you to lock the center diff without being in low range. There are certain situations where this can be useful, but of course, must be used with good judgement (as in, never on the pavement or other surface where there is good traction).
Once you are able to lock the center diff in high range, then any truck with OEM diff lockers can also be locked up (rear, then front) while in high range. Again, you have to use your head here, or you will toast your diriveline. HTH
Cheers, R -
PS: Thanks Adam... I'm just too slow
