center console cooler!! almost complete
Hi, im hoping you can help me! i have an hdj81 vx landcruiser, as you are properly aware they come from factory with all the same looms, despite not having all the factory options. i have retro fitted a center console cooler to mine. the only problem i have is there is no power to what i believe to be the "rear cooler magnetic switch". this is a solenoid mounted at the top passengers side of the engine bay. it has the ac line coming from the cabin and also the ac line from the center console cooler (also used for models with rear aircon unit) then it goes to the condenser at the front of the vehicle. it is operated by a little two wire black plug. my problem is this plug has no power going to it. there for it cant open or close. i am hoping this is because i am missing a fuse or relay some wear since my vehicle didn't have the cooler from factory. can any body shed some light on this?
many thanks
Liam
any 1? dose any 1 know what activates it? i can eaither replace it with a straight pipe, or keep it in and provide it with power myself
