Center Arm Assembly
Seville, OH
Was attempting to rebuild the center arm assembly on my 69 40 last night. The PO apparently never did this. Everything I read indicates that this should be a fairly easy job. Now, this is the older style center arm, not the cone shaped deal found on the newer 40's.
Everything went fine until I got everything apart. When I pulled the center shaft, apparently one of the bushings (or is it the race ? not sure) seems to be permanently affixed to the center shaft. I'm pretty sure these two pieces are supposed to come apart. The rebuild kit came with two replacments, but only one came off the center shaft.
I tried all the usual tricks - torch, BFH, penetrating oil, more torch and more BFH. But to no avail...
Here's a pic of the center shaft with it's now permanent friend;
Anybody run into this before ? Any hints as to a possible solution ?
Also, the kit came with two felt dust seals. But there were none in the actual assembly - maybe they disintegrated over the course of 36 years of abuse. Any idea how they fit in ? The diagrams I've seen don't reallly explain them. And the digrams in the Haynes manual only show the later conical center arm assemblys.
Besides the obvious answer - go to Power Steering, what's the right approach here ? Is it possible to purchase a complete rebuilt center arm assembly ? Or are the rebuild kits the only option ?
Do you have access to a shop press? That might work.
I changed mine out to the later style by boxing the framehorn and making a plate adapter for the crossmember.
GL
Ed
It's a pressed fit and heat shouldn't be used on that bearing steel. If you don't have a press just take it to a Napa store or any automotive machine shop - it'll take less than a minute.
Or............you could shine it all up and reuse it.
You won't find a new or rebuilt one like yours. Changing as Degnol described is a good fix but be sure to have the bellcrank arm as well as the box. Yours is threaded, new is splined.
The kit will work, but those felt things are a hassle. Soak them in oil or decide to use a combination of o-ring and RTV. Remember oil flows while grease only oozes :D
I'm pretty sure my neighbor has a shop press. He's got a full machine shop in his basement. He does some kind of government contract work. They don't really tell him what it's for, they just send him the specs and he machines the stuff for them. They pay him pretty well though.
Regarding the felt seals - I'm assuming that they go under the caps on each end of the assembly ? They just need to be compressed when installing so everyhting fits, hence the soaking with oil. Am I correct ?
It also appears that CCOT sells a rebuild kit, for the older assemblies, that comes with a new center shaft. At least it looks that way. Anybody ever get one of these kits from CCOT ? Does it come with the shaft too ?
No, I screwed up and got the SOR kit which doesn't come with the shaft. Come to find out CCOT sells a kit that does, and its cheaper. It also comes with both cap nuts - and still about $25 cheaper.
:doh:
