While on my way to work Monday morning, I was glancing at the speedometer and in that instant, saw the CEL illuminate. "Damn" I thought, not a great way to start the week..
When I got home that evening, I threw my OBD-II scan tool on it and pulled a P0401 code. I decided to check the other sensors while I was connected and noticed that everything was normal except the B1S2 O2 sensor. The Fuel Trim percentage was pegged at a positive 99.06% and the voltage for that sensor was fluctuating normally as expected. I took it for a road test and the Fuel Trim percentage never moved from 99.06% while the voltage still fluctuated as expected and within specifications.
Next, I followed the FSM diagnostics for the P0401 as best as I could, but found RT's diagnostics approach much better. The thread can be found here. After completing the diagnostics, I have determined that the EGR vacuum modulator is to blame for the P0401 in this case.
My question is this. Is it possible that a failed O2 sensor has cause the EGR vacuum modulator to fail or visa-versa? Or is this just coincidence? Either way, I think I'll be calling Dan to replace both O2 sensors and the modulator...
Thanks for any insight.
