CEL code 71: update on code 25/26 from previous post
Earlier I posted regarding a 25/26 CEL code. Here is what I have done to try and fix it and now I have a new code. My Family Cruiser vacation starts in 7 days so any help would be totally appreciated.
Update:
This last weekend I once again checked the wiring harness and it still looks good. I fumbled with the connectors at the O2 sensors and was not able to trip the CEL light either. My O2 sensors have been replaced in the last 50,000 miles and the vehicle idles nicely and gets around 15 mpg on the freeway. I also added a bottle of Fuel Injector Cleaner to a fresh tank.
I did find that the ground bolts to the body immediately beside the battery were totally loose. This probably occurred when I installed the Slee light harness, because we failed to re-tighten them.
I reset the CEL and drove the vehicle. The light came on on the second freeway trip I took. The code now reads a 71. I reset the code today and performed the test in the FSM to see if i could trip it again. 5 minutes on the freeway and I triped the CEL light and registered another code 71.
Before my last freeway drive I noticed two things (see photos). The yellow arrow is pointing to a wire connection that was disconnected. I don't know what this does or if it relates but I re-connected it.
The Red arrow is pointing to some sort of electrical connection that appears to be just lying across the top of the engine. I don't know what this does but I believe it is connected to the EGR vacuum modulator. Is this in the right spot? maybe it should be tied back away from any heat source?
I can't tell for sure, but I think the red arrow is pointing at the connector for the temp sensor for the EGR. If that was indeed unplugged, that could lead to EGR (code 71) issues.
The yellow arrow appears to be pointing to the heater control valve adjuster doodad.
Geo-Yes, that is the temp sensor connection. After your post I took a good look at it. It appears that there used to be some sort of insulation around those two wires you can see coming out of the connector. One of those grey wires was exposed a little bit so I taped them up with electrical tape and used a zip tie to pull the connector away from any heat source. I was stoked that this easy fix might be the cause of all my worries but:doh:. I test drove it twice afterward and came up with the codes 25/26/71.
I think I'm going to give up and take it in to a professional. I guess I was naive to think that I could do all the wrenching myself :frown:
I'll chime in about the code 71. The thing in your picture with the green top is the EGR modulator. I had a code 71 when I first purchased the vehicle and drove it for over a year with the CEL on. I ordered a new modulator from cdan and the code has not come back in over a month.
I have not had to deal with the 25/26 codes yet, but there is plenty out there that have. Search and yee shall find.
The temperature sensor that is pointed out by the red arrow is in the same place on my '94 LC.
The cable or wire that you pointed out in yellow opens and closes your heater valves I believe. I do not think it has anything to do with the CEL codes you are getting, but may help your feet stay warm:).
The large bundle of wires next to the temperature sensor could be a suspect and many here have found worn or severed wires in there that caused many CEL codes and strange engine performance.
I personally would start with a new EGR modulator from cdan and then address the O2 sensors next.
edit: Actually, codes 25/26 are air/fuel ratio warnings so I would check the large wiring harness after changing the EGR modulator.
Riley
